VLAN config on 2811 with Fa and HWIC
Jul 10th, 2008
I have a 2811 router with the 9port HWIC installed. I am trying to use the Fa0/0 port as an uplink to my corporate LAN for the VLAN that is configured on the HWIC. I have tried adding an IP directly to the Fa port and also tried creating dot1q subinterfaces on the Fa port with no luck. When I did this the local IPs could ping each other but no connection to the corporate LAN could be established. I resorted to using one of the HWIC ports as the uplink using the config below. How can I setup the Fa port as the uplink so I can free up the HWIC port I am currently using?
Diego
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/3/0
switchport mode trunk
switchport voice vlan 100
interface FastEthernet0/3/1
interface FastEthernet0/3/2
interface Vlan1
ip address 10.10.10.1 255.255.255.0
interface Vlan100
ip address 10.1.1.1 255.255.255.0
Overall Rating: 4 (2 ratings)
a.alekseev Thu, 07/10/2008 - 07:29
You cannot connect 9port HWIC to you internal LAN through onboard F0/0,F0/1 ports..
"interface Vlan100" and
"interface F0/0.100
enacap dot1q 100"
is not the same thing..
rsgamage1 Thu, 07/10/2008 - 08:03
How do you distinguish between them and what's the use of "interface Vlan" command?
DIEGO ALONSO Thu, 07/10/2008 - 08:04
I don't understand where you are going with that. Would you be so kind as to give more detail?
Diego
a.alekseev Thu, 07/10/2008 - 08:20
my english is not perfect :))
you have a router with two onboard ports (F0/0,F0/1) and one virtual port for HWIC access. The virtual port is a trunk to your HWIC. To access vlan 200 on HWIC you must create "interface vlan200".
But there is no briging between the virtual port and F0/0,F0/1.
So you can connect them each other only by routing.
glen.grant Thu, 07/10/2008 - 11:38
I believe that is the case with hwics , they are basically a standalone switch inserted into a router chassis .
