Call Receive with the Phone in Loggoff
Jul 10th, 2008
  • " /> Participante em Destaque,
    Prêmio"Escolha dos membros": novembro de 2014
Hi Guys,
The Customer requested a project of the following form: when the branch this loggoff it uses one numbers 98xx (false branch) for example, that only makes calls between branches and when the user if login (Extension Mobility) it uses one numbers 13xx (true branch) for example, that makes any type of calls. In this Project there is a Translation Pattern that transforms the come numbers of the users for one creaks of true branches. The Secretary has numbers trunk key 3512-0200 that only receives calls when this login during the 8:00 am to 7:00 pm. What it needs: That the calls receive in this trunk , will can be attendant with the trunk number without be login after this time.
Thank You,
Wilson
