Calls between Device Pools
Jul 10th, 2008
hi all,
I need to create two different Device Pools in one Call Manager 4.2(3) but when I do that the phones in one Device Pool Can't call to phones in the other one device Pool. All calls inside device pool works fine.
Any ideas?
thanks in advance
Jaime Valencia Thu, 07/10/2008 - 05:32
  • Cisco Employee,
  • Hall of Fame,
    2011
codecs must be the issue
javalenc
if this helps, please rate
carlosjlopez Thu, 07/10/2008 - 05:42
Hi Javalenc, thanks for your fast answer, both device pools are in the same region and use the same codec G711
Chris Deren Thu, 07/10/2008 - 05:38
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
What is the location set to on the DPs? If it's different ensure that the location configuration has enough bandwidth for the calls.
Also, what type of phones are these?
Chris
Jaime Valencia Thu, 07/10/2008 - 05:50
  • Cisco Employee,
  • Hall of Fame,
    2011
as far as i remember location is set on the device and not in the DP. but might be a good idea to check it anyway
what happens when you dial?? what do you hear??
javalenc
Chris Deren Thu, 07/10/2008 - 06:09
  • Hall of Fame,
In CM 4.2 and 6.X it is set in Device Pool.
Chris
Ayodeji Okanlawon Thu, 07/10/2008 - 06:41
    2017 IP Telephony
In CCM 4.2 and 6.X you can set the location on both the DP and the Device itself!
So please check what locations you have on both and ensure you have enough badnwidth for the call
