CAR database crosses 2 Million Mark
Jul 10th, 2008
i have received alert email everyday as below even i change min age 10 days and max age 45 days.
The number of records in the CAR database size had breached the 2 Million Mark (2000000 records).
The number of records in the CAR database was 2000124. After purging, number of records in the CAR database with 2000124 still crosses 2 Million Mark, hence CAR loader was stopped.
Please lower the Max and Min Number of Days of Records from the Auto-Purge page ASAP, to allow deletion of older records to keep size further below the 2 Million Records Mark.
i am using callmanager 6.1.
does any suggestion?
Overall Rating: 5 (1 ratings)
Jaime Valencia Thu, 07/10/2008 - 06:40
  • Cisco Employee,
  • Hall of Fame,
    2011
use CAR to purge manually some records
javalenc
if this helps, please rate
netstaradam Thu, 07/10/2008 - 09:41
i have been manual purge all records and reload all cdr but still receive alert mail.
may i check somewhere or something to identify problem?
Jaime Valencia Thu, 07/10/2008 - 09:48
  • Cisco Employee,
  • Hall of Fame,
    2011
you need to purge CAR, not CDR, different databases
javalenc
netstaradam Thu, 07/10/2008 - 10:26
i am use system>database>manual purge to delete all record and click table information to verify all record are zero but still receive alert email.
netstaradam Thu, 07/10/2008 - 10:51
my environment have two callmanager 6.1,CAR only enable at publisher,call processing at subscriber.
vhilario Thu, 07/10/2008 - 17:10
When login into CAR and go into Manual Purge there's a drop down menu under select database choose "CAR" and choose TBL_BILLING_DATA" and purge the data manually.
netstaradam Mon, 07/14/2008 - 08:48
I follow instruction to purge TBL_BILLING_DATA,TBL_BILLING_ERROR and TBL_BILLING_HISTORY successfully.
Now need to monitor a period of time.
greg.cas4 Tue, 11/22/2016 - 14:10
User Management -> User Settings -> Access Control Group -> Standard CAR Admin Users
Run a find and you'll see the users who receive these alerts.
