ACE SSL - bad certificate message
Answered Question
Jul 10th, 2008
hello guys,
I have basic www/https LB configuration on the ACE. in my lab was all working. now, in production, I have a problem with https connection. in sniffer output I can see after 3way handshake this:
SSLv3: Alert (Level: Fatal, description: Bad certificate)
what does it mean? I think, my SSL chain is correct (it's a certificate for the service and root certificate) - how can I verify certification chain? (analogous to CSM module).
thanks,
martin
Correct Answer by ciscocsoc about 8 years 9 months ago
The openssl code has a verify function which will check a certificate against a chain. The chain needs to be a concatentation of pem format certificates and your certificate also needs to be in pem format. See http://www.openssl.org/docs/apps/verify.html
Example:
C:\ACE\WIP\Myfiles>c:\openssl\bin\openssl verify -CAfile chain.pem cert_12505775
75.pem
cert_1250577575.pem: OK
Openssl also provides for changing the format if necessary.
Cathy
Overall Rating: 3 (1 ratings)
Roble Mumin Fri, 07/11/2008 - 09:06
  • Bronze, 100 points or more
If i recall correct you verify a cert with...
crypto verify
in enable mode.
I don't have an ACE here right now so i can't check. But give it a try.
Roble
Martin Kyrc Sun, 07/13/2008 - 21:32
yes, with 'crypto verify ...' it's possible verify certificate and key pair. but how it's possible verify full certification chain (ca-root-cert, ca-cert, service-cert)?
the problem is solved - there was really bad certificate (but cert/key matched).
Correct Answer
ciscocsoc Mon, 07/14/2008 - 00:37
  • Silver, 250 points or more
Example:
75.pem
Cathy
Martin Kyrc Wed, 07/16/2008 - 01:15
yes, of course. openssl has this possibility, ACE hasn't (CSM has this possibility, maybe in new releases comes to ACE also).
thanks,
martin
