Richard Atkin Thu, 07/10/2008 - 07:29
Unfortunately it's only a 2D feature, WCS map coverages doesn't consider signals that come from other floors.
Rgds,
Richard
jessejdavis Thu, 08/21/2008 - 10:18
Perhaps that's something that should be considered for future versions. Even if you have APs on every floor, you are going to get signal penetration. The way that it is now, the heat maps aren't as accurate as they could be.
Trending Topics - Security & Network
