ASA and hairpinning(redirecting of ip traffic)
Jul 10th, 2008
Does anyone have a solid, proven way of doing this?
I have an ASA-8.03 version with an inside interface 172.16.0.1/24 and have another network via 172.16.0.2(router) to the network 192.168.10.0/24.
I setup the "permit intra-interface traffic" command and added a static route "route inside 192.168.10.0 255.255.255.0 172.16.0.2 1"
and also setup a nat (inside) 0 access-list nonat
In the nonat acl i have permit ip 172.16.0.0 255.255.255.0 192.168.10.0 255.255.255.0
Doing all this allows icmp packets to and from the given networks. But not an tcp traffic! What am I missing. Any Idea's. I have tried using different static nat statements as well with no luck. If you have ip redirects working an an ASA please let me know what you have done to accomplish this.
Thanks In Advance,
Pat B
acomiskey Thu, 07/10/2008 - 08:13
Give this a try instead of nat 0.
global (inside) 1 interface
nat (inside) 1 172.16.0.0 255.255.255.0
May not be exactly what you want, but it should work.
srue Thu, 07/10/2008 - 08:19
nonat acl that permits 192.168.10.0/24 172.16.0.0/24 ?
can you post the config?
do you have an acl applied to your inside interface?
