Bind SIP dial-peer to secondary H323 source IP
Jul 10th, 2008
I would like to do some testing with my SIP provider. They use the h323 source IP address (loopback) from my gateway for billing purposes. What they would like from me is to use another interface IP to complete this testing so charges will not accrue. Is there a way to essentially bind one or two dial-peers to source from the secondary interface IP while allowing all other traffic/dial-peers to be source from the billing IP?
Thank you for your time,
gogasca Thu, 07/10/2008 - 09:50
If you use SIP dial-peers use sip bind commands under voice service voip
melissajwright Thu, 07/10/2008 - 11:14
Thank you for the response.
I have my bind statements under voice service voip to use my current H323 interface as you suggested. I want to have multiple bind control source-interface and bind media source-interfaces for testing purposes. What I want to be able to is to force certain dial-peers to use one interface over another. How would that be configured (if possible)?
Thank you!
