ASA 5505 has me stuch in the mud
Answered Question
Jul 10th, 2008
I have an asa 5505 and nearly everything works great. my only problem is I have a webserver in the DMZ and I can't get access to the internet from it. Now if it was just that i wanted to be able to get updates for the box it wouldn't matter but i have an app on the server that has to communicate via ssl with a service outside my network and no traffic goes out that is destined for the internet. The server also accesses a database on the inside network and this works fine. I need a hand, badly.
Correct Answer by srue about 8 years 9 months ago
no access-list outside_access_in extended permit tcp any host 64.181.65.243 eq www
access-list outside_access_in extended permit tcp any interface outside eq www
Correct Answer by a.alekseev about 8 years 9 months ago
access-list dmz_access_in extended permit tcp host 192.168.3.2 host 192.168.2.3 eq 1433
access-list dmz_access_in extended deny ip any 10.0.0.0 255.0.0.0
access-list dmz_access_in extended deny ip any 172.16.0.0 255.240.0.0
access-list dmz_access_in extended deny ip any 192.168.0.0 255.255.0.0
access-list dmz_access_in extended permit ip 192.168.3.2 any
access-group dmz_access_in in interface dmz
nat (dmz) 1 192.168.3.2
Correct Answer by kwillacey about 8 years 9 months ago
You need to change the
nat (inside) 1 192.168.3.0 255.255.255.0 TO
nat (dmz) 1 192.168.3.0 255.255.255.0
That should fix your problem.
Overall Rating: 3.5 (6 ratings)
Correct Answer
kwillacey Thu, 07/10/2008 - 09:32
  • Bronze, 100 points or more
Correct Answer
a.alekseev Thu, 07/10/2008 - 09:48
  • Gold, 750 points or more
bhoskisnon Thu, 07/10/2008 - 11:13
I hate to say it but that didn't do it. I can see in the syslog the connections being built and then the teardown nearly 2 minutes later. the connections seem to be good, here are the teardowns.
6 Jul 10 2008 18:53:53 302014 64.181.65.242 192.168.3.2 Teardown TCP connection 318 for outside:64.181.65.242/4404 to dmz:192.168.3.2/80 duration 0:01:17 bytes 38852 TCP Reset-O
6 Jul 10 2008 18:54:48 302016 63.90.97.10 192.168.3.2 Teardown UDP connection 320 for outside:63.90.97.10/53 to dmz:192.168.3.2/1026 duration 0:02:08 bytes 180
6 Jul 10 2008 18:55:10 305012 192.168.3.2 64.181.65.243 Teardown dynamic UDP translation from dmz:192.168.3.2/1026 to outside:64.181.65.243/1025 duration 0:02:30
the webserver just times out on the connections internet pages are un accessable and name resolution doesn't happen when i use ping to see if it will resolve the name. I dont know what the issue is, it's making me nuts!
srue Thu, 07/10/2008 - 11:15
  • Blue, 1500 points or more
do you have a base license installed?
show version
if it's a base license, try:
int vlan 12
no forward interface vlan 1
a.alekseev Thu, 07/10/2008 - 11:23
What actual configuration do you have?
could you post it?
bhoskisnon Thu, 07/10/2008 - 11:32
I am running the security plus license and my version is 8.0(3). The config I attached is the config i was running below is the new config with the changes suggested above.
: Saved
ASA Version 8.0(3)
hostname ciscoasa
enable password xxx
names
interface Vlan1
nameif inside
security-level 100
ip address 192.168.0.4 255.255.255.0
interface Vlan2
description Fibernet
nameif outside
security-level 0
ip address 64.x.x.243 255.255.255.248
interface Vlan12
description DMZ
nameif dmz
security-level 50
ip address 192.168.3.1 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
switchport access vlan 12
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd xxx
ftp mode passive
access-list chasjfg_splitTunnelAcl standard permit any
access-list inside_nat0_outbound extended permit ip any 192.168.0.176 255.255.255.240
access-list dmz_access_in extended permit ip host 192.168.3.2 any
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu dmz 1500
ip local pool vpn 192.168.0.180-192.168.0.189 mask 255.255.255.0
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-603.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 192.168.0.0 255.255.255.0
static (dmz,outside) tcp interface www 192.168.3.2 www netmask 255.255.255.255
static (inside,dmz) 192.168.2.3 192.168.0.3 netmask 255.255.255.255
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 64.181.65.241 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.0.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
more in next post
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
no crypto isakmp nat-traversal
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
threat-detection basic-threat
threat-detection statistics
group-policy chasjfg internal
group-policy chasjfg attributes
dns-server value 192.168.0.51
vpn-tunnel-protocol IPSec
split-tunnel-policy tunnelspecified
split-tunnel-network-list value chasjfg_splitTunnelAcl
default-domain value jacobsandco.local
username bhoskinson password XXX
username bhoskinson attributes
vpn-group-policy chasjfg
tunnel-group chasjfg type remote-access
tunnel-group chasjfg general-attributes
address-pool vpn
default-group-policy chasjfg
tunnel-group chasjfg ipsec-attributes
pre-shared-key *
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:xxx
: end
Correct Answer
srue Thu, 07/10/2008 - 11:35
bhoskisnon Thu, 07/10/2008 - 12:00
still the same with the same statements in the syslog
bhoskisnon Thu, 07/10/2008 - 12:08
I wouldn't think this would be all that out of the ordenary. all I want to do is have a webserver in the dmz i want to get to it from the internet over http and https (if i can get the stupid thing to talk to the internet) I want to be able to access the internet from my webserver on my dmz (dns, http, https, and what ever openssl uses and I want my webserver to be able to access my sql server from my web application on the dmz.
I know this should be fairly commen I just can't make it work.
a.alekseev Thu, 07/10/2008 - 12:31
you webserver can be accessed from the internet.
do you have internet acces from the server?
could you ping from the server 64.181.65.241?
bhoskisnon Thu, 07/10/2008 - 12:47
Thank you all for your help. but some times it takes a fresh set of eyes. while there where some problems with my config that where causing things not to work, a secound issueon the webserver it's self was also contributing to the road block. A buddy looking over my shoulder as i watched the syslog go by when i tried to access the internet said "hey your dns server address is wrong!" I had mistyped the 3rd number in the dns server address on the web server. It is always the small things that get you when you get too close to the problem. Thanks again for the help.
