07-10-2008 10:21 AM - edited 03-14-2019 02:31 AM
Is it possible to add custom fields in the outbound desktop layout.
Actually I have dialing list which has account number and the customer contact no. Customer contact number is displayed on the outbound desktop but account number is not displayed.
The same has been already defined in the query rule.
Can I add my own custom fields onto the outbound desktop. I am running ctios outbound client on IPCC enterprise.
Any suggestions....
07-10-2008 10:28 AM
Sure. Go to the registry of CTIOS and edit the appearance. You can turn off the standard columns on display and display other call variables or even ECC variables.
There are samples - in your case, blended agent is what you might find useful.
C:\icm\CTIOS_bin>dir /b *.reg.txt
agentstatistics.default.reg.txt
blendedagent_addecc.reg.txt
callappearance.default.reg.txt
skillgroupstatistics.default.reg.txt
Geoff
07-10-2008 11:09 AM
HI Geoff,
Thanks for the info.
Actually I have both normal agents working and blended agents working in the call center.
I wanted to customize the grid columns only for blended agents.
Is it possible to export the blendedagent_addecc.reg.txt directly to the registry instead of manually editing the registry entries..
07-10-2008 11:51 AM
No, that's not possible - all for one and one for all.
You can rename this file as a .reg file and import it into the registry. This is standard Windows functionality.
You really want to be careful how you do this.
What I suggest is export your current CTIOS config and import it to your laptop. Then you can create the custom .reg file with a decent editor and import, return to default, import etc until you get it right.
Now that you have a .reg file that works, wait for a maintenance window and stop the CTIOS, import the .reg, restart.
Geoff
