ACS Appliance 1113 with v4.2
stanleyworks
I have ACS appliance 1113 with v4.2 software. How do I tight this into Active directory? Do I have to run some software on the DC server?
Jagdeep Gambhir
Level 10
Level 10
You need to install remote agent on member server. The software will facilitate communication between acs and AD.
Here is the link,
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_solution_engine/4.1/installation/guide/remote_agent/rawi.html
~JG
Do rate helpful posts
Just to confirm, I also have the same scenario, to integrate with Active Directory I need the Remote Agent installed in the AD server itself? I configured as Generic LDAP and I can see the groups within my AD but instead I need to configure it as Windows Database?
