Dial Peer Configuration Help
Jul 10th, 2008
On an H323 gateway what dial peer do I need to configure to route an inbound 800 number that is coming in on a CAS T-1 sending the last four digits as the DNIS. Currently this T-1 is only being used for outbound traffic.
Dianna
paolo bevilacqua Thu, 07/10/2008 - 11:08
  • Hall of Fame,
    Founding Member
Like:
dial-peer voice 1234 voip
destination-pattern 1234
session target ipv4:x.x.x.x
codeg g711u
no vad
dtmf-relay rtp-npe
Please rate post if it does!
dfhensley Thu, 07/10/2008 - 11:22
This didn't work for me. When calling the number I get dead air, no ring back.
Ayodeji Okanlawon Thu, 07/10/2008 - 11:43
  • Cisco Designated VIP,
    2017 IP Telephony
can you post your full config here
paolo bevilacqua Fri, 07/11/2008 - 01:53
  • Hall of Fame,
    Founding Member
Does the CM knows about the called DID?
Next step would be debugs like "cch323" with "term mon".
Ayodeji Okanlawon Fri, 07/11/2008 - 09:30
    2017 IP Telephony
Your dial-p voice 411 below specifies a 4 digit number. However you said the inbound number is 800
can you tell me the full number delievered to your gateway.
You can know this by doing a dbug isdn q.931 and place a test call to the number...
dial-peer voice 411 voip
destination-pattern [0-8]...
progress_ind setup enable 3
modem passthrough nse codec g711ulaw
session target ipv4:10.34.0.11
dfhensley Fri, 07/11/2008 - 09:52
This is the message I got when I did the debug and called the number. Telco is suppose to be sending 4191 as the dnis. The whole number is 877-367-4191
Dianna
Jul 11 13:46:09.132: ISDN Se0/0/1:23 Q931: TX -> CONNECT pd = 8 callref = 0x807D
Jul 11 13:46:09.168: ISDN Se0/0/1:23 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x007D
Jul 11 13:46:09.168: ISDN Se0/0/1:23 **ERROR**: call_progress: DEV_CONNECTED VOICE ERROR: Bearer capability not available(0x3A): b channel 2 call id 0
x28CC
Ayodeji Okanlawon Fri, 07/11/2008 - 10:04
    2017 IP Telephony
I need to see the full debug..including the part that showed the calling and called number and also the cuase code..
send the full output
