Branch site's LAN not being learned via OSPF
alexlembesis
If anyone can help me, it would be greatly appreciated and help my throbbing headache. I'm setting up a test environment that looks like the following.
(Branch 2821 ATM/T1)---ATM T3---(WAN 7200 )---100Mb---(Core)
The problem I'm having is that the branch LAN subnet is not populating the WAN router's OSPF database. I can ping the Branch's ATM '/30' subnet fine from core, but can not ping the LAN subnet from anywhere but the Branch router. A simple "show ip route 10.190.105.0" shows the following. Configs are attached. Any takers?
RTR0286-BLSB-WAN#show ip route 10.190.105.1
Routing entry for 10.160.0.0/11
Known via "bgp 101", distance 200, metric 0, type locally generated
Redistributing via ospf 100
Routing Descriptor Blocks:
* directly connected, via Null0
Route metric is 0, traffic share count is 1
AS Hops 0
Hello Alex,
I supposed it could deal with ospf network type.
I'm happy to know that my suggestion was right.
Have a nice weekend
Thank you for the points you have already given me.
Giuseppe
19 Replies 19
Richard Burts
Alex
I believe that I see the problem. on the branch router area 10.190.105.0 is a normal area. But on the WAN router is is declared as stub:
area 10.190.105.0 stub
the mismatched area type will prevent the routers from becoming neighbors and sharing routes.
Either make it stub on the branch or make it normal area on the WAN router.
Rick
Rick
Still the same thing... Although now they ARE neighbors.
AS Hops 0
on both sides
ip ospf hello-interval 10
that didn't help either :( Thanks for all of your quick responses guys. I noticed that a 'show ip ospf border-routers' shows nothing...
here's a show ip ospf database from the branch router...
Branch#show ip ospf database
OSPF Router with ID (10.189.251.218) (Process ID 100)
Router Link States (Area 10.190.105.0)
Link ID ADV Router Age Seq# Checksum Link count
10.161.254.2 10.161.254.2 810 0x80000020 0x000550 2
10.189.251.218 10.189.251.218 809 0x80000002 0x007FB6 2
Net Link States (Area 10.190.105.0)
10.189.251.218 10.189.251.218 809 0x80000001 0x004472
Summary Net Link States (Area 10.190.105.0)
0.0.0.0 10.161.254.2 1540 0x80000001 0x00454C
Alex
Some additional information might be helpful. Would you post the output of show ip interface brief, and also show ip ospf interface (and while we are at it perhaps the output of show ip ospf)?
There is a network statement that should include 10.190.105.1 but it is not showing up in the link state data base. I wonder if there is some issue with that interface - is it perhaps in the state of up/down or is there some reason why it is not in the link state data base of the branch router?
Rick
Rick
Rick,
As you requested.
Branch#show ip int brief
GigabitEthernet0/0 10.190.105.1 YES manual up up
GigabitEthernet0/1 unassigned YES NVRAM administratively down down
ATM0/1/0 10.189.251.218 YES NVRAM up up
Branch#show ip ospf interface
GigabitEthernet0/0 is up, line protocol is up
Internet Address 10.190.105.1/24, Area 10.190.105.0
Process ID 100, Router ID 10.189.251.218, Network Type BROADCAST, Cost: 1
Transmit Delay is 1 sec, State DR, Priority 1
Designated Router (ID) 10.189.251.218, Interface address 10.190.105.1
No backup designated router on this network
Timer intervals configured, Hello 10, Dead 40, Wait 40, Retransmit 5
oob-resync timeout 40
Hello due in 00:00:06
Supports Link-local Signaling (LLS)
Cisco NSF helper support enabled
IETF NSF helper support enabled
Index 1/1, flood queue length 0
Next 0x0(0)/0x0(0)
Last flood scan length is 0, maximum is 0
Last flood scan time is 0 msec, maximum is 0 msec
Neighbor Count is 0, Adjacent neighbor count is 0
Suppress hello for 0 neighbor(s)
ATM0/1/0 is up, line protocol is up
Internet Address 10.189.251.218/30, Area 10.190.105.0
Process ID 100, Router ID 10.189.251.218, Network Type NON_BROADCAST, Cost: 65
Designated Router (ID) 10.189.251.218, Interface address 10.189.251.218
Backup Designated router (ID) 10.161.254.2, Interface address 10.189.251.217
Hello due in 00:00:03
Index 2/2, flood queue length 0
Next 0x0(0)/0x0(0)
Last flood scan length is 1, maximum is 157
Last flood scan time is 0 msec, maximum is 4 msec
Neighbor Count is 1, Adjacent neighbor count is 1
Adjacent with neighbor 10.161.254.2 (Backup Designated Router)
Branch#show ip ospf
Routing Process "ospf 100" with ID 10.189.251.218
Start time: 02:10:18.016, Time elapsed: 20:21:41.960
Supports only single TOS(TOS0) routes
Supports opaque LSA
Supports area transit capability
Router is not originating router-LSAs with maximum metric
Initial SPF schedule delay 5000 msecs
Minimum hold time between two consecutive SPFs 10000 msecs
Maximum wait time between two consecutive SPFs 10000 msecs
Incremental-SPF disabled
Minimum LSA interval 5 secs
Minimum LSA arrival 1000 msecs
LSA group pacing timer 240 secs
Interface flood pacing timer 33 msecs
Retransmission pacing timer 66 msecs
Number of external LSA 0. Checksum Sum 0x31F690
Number of opaque AS LSA 0. Checksum Sum 0x000000
Number of DCbitless external and opaque AS LSA 0
Number of DoNotAge external and opaque AS LSA 0
Number of areas in this router is 1. 0 normal 1 stub 0 nssa
Number of areas transit capable is 0
External flood list length 0
Area 10.190.105.0
Number of interfaces in this area is 2
It is a stub area
Area has no authentication
SPF algorithm last executed 00:01:59.280 ago
SPF algorithm executed 3 times
Area ranges are
Number of LSA 4. Checksum Sum 0x140E984
Number of opaque link LSA 0. Checksum Sum 0x000000
Number of DCbitless LSA 0
Number of indication LSA 0
Number of DoNotAge LSA 0
Flood list length 0
Alex
This is quite puzzling. The output that you posted here shows that Gig0/0 is in the right state and that it is an active OSPF interface (and the branch router is the DR for the segment, as would be expected). But the output of the OSPF link state data base which you previously posted does not show this network in the link state data base. Is it possible that the content of the link state data base has changed and that the network is now included in the data base?
Rick
Rick
Yeah i'm having a helluva time figuring this out. I got the WAN router to see the Branch's LAN subnet for about 10 seconds when I changed the ospf network type on the GigabitEthernet interface to point-to-multipoint. Then out of no where, DEAD... back to Null0. Excuse me for the long post... Does this mean anything?
*Jul 11 16:06:01 UTC: OSPF: end of Wait on interface GigabitEthernet0/0
*Jul 11 16:06:01 UTC: OSPF: DR/BDR election on GigabitEthernet0/0
*Jul 11 16:06:01 UTC: OSPF: Elect BDR 10.189.251.218
*Jul 11 16:06:01 UTC: OSPF: Elect DR 10.189.251.218
*Jul 11 16:06:01 UTC: OSPF: Elect BDR 0.0.0.0
*Jul 11 16:06:01 UTC: DR: 10.189.251.218 (Id) BDR: none
*Jul 11 16:06:01 UTC: OSPF: Send hello to 224.0.0.5 area 10.190.105.0 on GigabitEthernet0/0 from 10.190.105.1
*Jul 11 16:06:02 UTC: OSPF: No full nbrs to build Net Lsa for interface GigabitEthernet0/0
*Jul 11 16:06:02 UTC: OSPF: Rcv hello from 10.161.254.2 area 10.190.105.0 from ATM0/1/0 10.189.251.217
*Jul 11 16:06:02 UTC: OSPF: End of hello processing
*Jul 11 16:06:03 UTC: OSPF: Send hello to 10.189.251.217 area 10.190.105.0 on ATM0/1/0 from 10.189.251.218
Branch(config-if)#
Branch(config-if)#
*Jul 11 16:06:11 UTC: OSPF: Send hello to 224.0.0.5 area 10.190.105.0 on GigabitEthernet0/0 from 10.190.105.1
*Jul 11 16:06:12 UTC: OSPF: Rcv hello from 10.161.254.2 area 10.190.105.0 from ATM0/1/0 10.189.251.217
*Jul 11 16:06:12 UTC: OSPF: End of hello processing
*Jul 11 16:06:13 UTC: OSPF: Send hello to 10.189.251.217 area 10.190.105.0 on ATM0/1/0 from 10.189.251.218
*Jul 11 16:06:21 UTC: OSPF: Send hello to 224.0.0.5 area 10.190.105.0 on GigabitEthernet0/0 from 10.190.105.1
*Jul 11 16:06:22 UTC: OSPF: Rcv hello from 10.161.254.2 area 10.190.105.0 from ATM0/1/0 10.189.251.217
*Jul 11 16:06:22 UTC: OSPF: End of hello processing
*Jul 11 16:06:23 UTC: OSPF: Send hello to 10.189.251.217 area 10.190.105.0 on ATM0/1/0 from 10.189.251.218
10.161.254.2 10.161.254.2 158 0x8000006A 0x00709A 2
10.189.251.218 10.189.251.218 401 0x80000002 0x007FB6 2
10.190.105.1 10.190.105.1 2247 0x80000003 0x0055B6 2
10.189.251.218 10.189.251.218 401 0x80000001 0x004472
0.0.0.0 10.161.254.2 1403 0x80000017 0x001962
Branch#show ip ospf neighbor
Neighbor ID Pri State Dead Time Address Interface
10.161.254.2 1 FULL/BDR 00:00:30 10.189.251.217 ATM0/1/0
I am unclear why but I at time will not see all the link information in the show ip ospf database command. I have many times had to specify the router parm to get this
So it may be helpful to issue
sh ip ospf database router 10.189.251.218
both on the branch router and the 7200 on the far end of the ATM. In theory it should be identical. You want to look for the lan subnet in this display. Since it is a OSPF interface it has to be someplace you would think.
Now if it is there on the 7200 router in particular then its a matter of determining why its does get placed in the routing table.
Alex
There have been enough changes that perhaps it would be helpful to post the current config (especially of the branch) again.
It occurs to me to wonder if you might be doing any kind of vrf processing? Perhaps the complete router config might help us to understand the context better.
Rick
Rick
Your wish is my command
Giuseppe Larosa
Hello Alex,
from your original post
core router:
interface ATM1/0.8 point-to-point
bandwidth 1536
ip address 10.189.251.217 255.255.255.252
pvc 0/41
vbr-nrt 1535 1535 1
encapsulation aal5snap
the ospf network type on core is point-to-point
on the branch
interface ATM0/1/0
description ATM-to-WAN
bandwidth 1536
ip address 10.189.251.218 255.255.255.252
no scrambling-payload
no atm auto-configuration
I think this a NBMA ospf network type and it s.
from sh ip ospf interface
Process ID 100, Router ID 10.189.251.218, >>Network Type NON_BROADCAST, Cost: 65
Try to move your configuration to an atm subinterface and makes it point-to-point it should solve your issue.
Hope to help
Giuseppe
That did the trick! Thanks everyone! I was VPN'd in till a little past midnight trying to figure this one out... now I'm kicking myself because it was something so simple! Oh well, at least it's friday! Have a good weekend!
oh crap,
Giuseppe, I forgot to check the "resolved my problem" box. Would you be a sport and just post something real quick so you get the credit? Thanks.
