CSA-MC on 2003 Virtual Server
Jul 10th, 2008
Is this possible ?
Has anyone successfully run the CSA-MC
on a windows 2003 virtual server instance ?
Any pointers, or direction is appreciated
Overall Rating: 5 (1 ratings)
tsteger1 Thu, 07/10/2008 - 13:29
I've installed it on VMware ESX and GSX (Now the free VMware Server product) with no problems but I haven't used MS Virtual Server.
Best thing to do is give it a try... it should be possible.
TradeSecrets Fri, 07/11/2008 - 06:38
If you have the money, buy the VMware ESX Server 3.5. It works great. I have a wonderful csa-mc pre-production environment, I use it for testing policies and virus's
They do have some free versions that work pretty good. But Vmware runs the show.
straussws Fri, 09/26/2008 - 17:46
GSX and MS Virtual Server are both free and work OK, but I'd love to buy ESX or latest flavor of VMware.
Be that as it may, I am running the CSA MC on a vm in MS Virtual Server. It is working OK, except that some process keeps tripping the untrusted root kit condition, and its an "unknown" process. I have a suspicion it is the add-on service for Virtual Machine Additions Service, which is not necessarily required for operation.
