CCNP Re-Certification
Answered Question
Jul 10th, 2008
I need further clarification, Can I take any of the one (1) 642 exams in order to re-certify my CCNP?
Bob.
Correct Answer by scottmac about 8 years 6 months ago
As long as it has not expired, yes.
Correct Answer by rob.huffman about 8 years 6 months ago
Hi Bob,
Yes, any 642 Level exam will recertify your CCNP :)
CCNP, CCDP, CCIP, CCSP & CCVP certifications Complete one of the following recertification options:
Pass any 642 exam that is part of the professional level curriculum after 01/01/06
Pass any current CCIE or CCDE written exam.
http://www.cisco.com/web/learning/le3/learning_about_recertication.html#ccnp_ccdp_ccip_ccsp_ccvp
http://www.cisco.com/web/learning/le3/le2/le37/le54/learning_certification_type_home.html
Hope this helps!
Rob
Overall Rating: 5 (2 ratings)
Correct Answer
rob.huffman Thu, 07/10/2008 - 13:32
Hi Bob,
Hope this helps!
Rob
zurita212001 Mon, 09/15/2008 - 06:55
I have another question in reguards to Re-certification. Does the re-cert have to be done by the date of your expertation date or before the end of the month of your experation date?
scottmac Mon, 09/15/2008 - 09:51
By the expiration date.
If it falls on a holiday, then before the holiday. The expiration date is absolute and is not adjusted out for any reason: any conflicts are resolved to BEFORE the expiration date.
