UC500 AA and Registered SIP Trunk
Jul 10th, 2008
Hi Netpro,
I found AA/Voicemail does not coexist with a registered sip trunk on UC500. Does anyone else have this experience?
My config is as follows:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
sip
registrar server expires max 3600 min 3600
outbound-proxy ipv4:58.28.20.150
no update-callerid
sip-ua
authentication username xxxxxxxxxxx password 7 xxxxxxxxxxx
no remote-party-id
retry invite 2
retry register 10
timers connect 100
registrar dns:as.wxcnz.net expires 3600
sip-server dns:as.wxcnz.net
host-registrar
As soon as I remove the command 'outbound-proxy ipv4:58.28.20.150', AA starts working.
With this command applied, 'Debug ccsip message' shows a 'Not found' messages from CUE.
Any guidance will be appreciated.
rhugo Mon, 07/14/2008 - 16:40
  • Bronze, 100 points or more
You also might try the "sip bind" config under your "voice service voip" config:
voice service voip
sip
bind control source-interface (likely the interface that terminates the 58.28.20.150 connection)
Here is a web link to the command set......might want to make sure your IOS supports it:
http://www.cisco.com/en/US/docs/ios/12_3/sip/configuration/guide/chapter7.html#wp1008876
Chuan Liu Mon, 07/14/2008 - 16:48
Thanks a lot. It is really appreciated.
I have solved the problem. I missed one command under the dial-peer pointing to CUE:
voice-class sip outbound-proxy ipv4:10.1.10.1
Thanks again for the links.
