Jaime Valencia Thu, 07/10/2008 - 13:47
  • Cisco Employee,
  • Hall of Fame,
    2011
check the transfer settings for that users subscriber to have it set to ring the subscriber's phone
javalenc
if this helps, please rate
Jaime Valencia Thu, 07/10/2008 - 13:50
  • Cisco Employee,
  • Hall of Fame,
    2011
what's the call flow?
javalenc
vhilario Thu, 07/10/2008 - 14:30
We can check that with traces enabled, or by u telling us how is the call.
Meaning: Call comes from the pstn, hitting and mgcp, h323 gateway, going to CCM (version) then phone "A" should ring and instead goes to VM.
or when hitting a callhandler from unity and dial by extension goes directly to VM.
That's how you tell the call flow, so as JAVALENC said, What's the call flow?
rcrumm_2 Thu, 07/10/2008 - 14:52
1. From my desk I call his extension. call goes to vm.
2. calls from PSTN hit h323 GW, then ccm 4.1.3, should ring at x6543, but directly to vm
Randall
Jaime Valencia Thu, 07/10/2008 - 14:55
  • Cisco Employee,
  • Hall of Fame,
    2011
you might have replication issues, try setting and unsetting CFA on that DN
javalenc
vhilario Thu, 07/10/2008 - 15:42
Can you please restart the DBL layer monitor service on all your servers and see if that helps.
Also checked if the phone does not have the callforward all to VM.
vhilario
