Set DID Number to Go straight to Channel 1 of Voice T1
I need to set up a DID number that will be routed out the first Channel of a Voice T1 currently in a 2811. Currently I have this, but this will be going away..
dial-peer voice 1 voip
incoming called-number 800XXXXXXX
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
The X's in the 800 are just placeholders, it has the full number in the config, but I just wanted to X'em out. Any help get a Free Slurpee..
mciarfello Sat, 07/12/2008 - 22:11
Re-phrase the question. What are you trying to do and what is the other side expecting. DID is direct INWARD dialing. Then you say routed OUT the first channel. Doesn't make sense.
You can't control what channel an incoming call takes. Your PBX or PSTN provider does that. You also don't have a dial-peer voice pots that ties to the T1. The dial-peer voice VOIP doesn't do anything with voice T1's.
Do you want a certain call to go out the first channel of a T1 CAS?
Anyways, you might be able to set up two channel-groups in your controller t1. First channel group has one channel defined. The second has the other channels (2-24). The dial-peer voice xxx pots will send your call out the first channel group.
