1711 VPN, ISA, QOS, issue
Jul 10th, 2008
  • Bronze, 100 points or more
at work we're trying to do QOS for the vpn link from our office to one of our other offices
we're using the Crypto map command for the VPN
the topo is
Lan--ISA firewall--1711--(internet)--1711-ISA firewall--LAN
the VPN is from 1711 to 1711
we want to use the RSVP command and base it on DSCP
we have the QOS preclassify command on the map already but its not matching any packets the VoIP sys is an avaya so we ran Wireshark on a temp hub (that we temporarly inserted inbetween the avaya and the switch) and found dscp 0x22
any ideas?
Overall Rating: 5 (2 ratings)
a.alekseev Thu, 07/10/2008 - 22:24
  • Gold, 750 points or more
bad idea because nobogy can guarantee you QoS in the internet.
is66rlhntadm Fri, 07/11/2008 - 05:23
just need to guarantee a bandwidth slice of the internet facing T-1
I realize after its on the internet it'll be encrypted and thus not matchable till the other 1711 de-cryptes it.
so the idea is to reserve some of the T-1 so that if a large file is being sent over the VPN that the VoIP can still have enough bandwidth to be understandable.
is66rlhntadm Wed, 08/20/2008 - 08:06
can someone help?
and we've changed priority is more important than bandwidth?
