Unable to connect to c1131AG Access Point via Web Browser
Jul 10th, 2008
Having problems using the Web GUI on a c1131AG LWAPP Access Point. Every time I attempt to connect, the AP returns a TCP RST (reset) to the initial TCP SYN request. This is the same for both http & https.
Have check various browers (IE/Firefox etc) and allow "pop-ups".
Can connect into the WiSM GUI - no prblems, just no luck with the APs - which can be controlled by the WiSM GUI etc.
Is there something really basic I'm missing here???
Does the AP need to enable web access?
Any hints would be appreciated.
Andrew
Overall Rating: 5 (1 ratings)
drewgeeing Fri, 07/11/2008 - 14:47
Thanks - that makes sense and I was starting to think along those lines, just couldn't find any Cisco doco that stated that fact - seems all the c1130 AP doco I read must referred to autonomous mode APs.
Cheers
