Look at the interface stats on the switch for the server ports,
Show interface fa0/1
FastEthernet0 is up, line protocol is up
Hardware is Lance, address is 0060.3ef1.702b (bia 0060.3ef1.702b)
115331 packets input, 27282407 bytes, 0 no buffer
Received 93567 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
143782 packets output, 14482169 bytes, 0 underruns
0 output errors, 1 collisions, 5 interface resets
0 babbles, 0 late collision, 7 deferred
0 lost carrier, 0 no carrier
perhaps you have a routing issue, or perhaps you have errors on
your switch ports, bad cable etc ....... need more information on your setup.
You can monitor a port on a switch via a span session:
http://www.cisco.com/warp/public/473/41.html
You can use various debug commands; see here http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_25_sea/command/reference/debug.html
HTH - Please rate if it does.
Stephen
http://www.rconfig.com
A free, open source network device configuration management tool, customizable to your needs!
- Always vote on an answer if you found it helpful
