07-11-2008 12:02 AM - edited 03-06-2019 12:08 AM
I am a new Cisco user and I am configuring a Cisco 877. It is going well with one exception; I have configured the address of the router "self" to be 10.4.19.3, however, when I connect the router I get an IP conflict with the main server which is on IP address 10.4.19.1.
There is no mention of this address anywhere in the router configuration except for a few static entries in the NAT route list for SSH, POP3 etc.
Can you think of any common errors that newbies make in this area.
07-11-2008 12:08 AM
hi,
can You show this static NAT's ? maybe is in wrong diresction? :)
regards
romek
07-11-2008 12:22 AM
Thank you for such a quick response !
Here is my NAT list; I have overtyped the outside static IP with IP with x.x.x.x as I am not sure what the company policy is on making this external static IP public domain.
I am using gui SDM as I have not got into IOS yet and it is a small router.
BTW, I have disabled DHCP as the main LAN server does that.
John
ip http server
ip http access-class 2
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer1 overload
ip nat outside source static tcp x.x.x.x 22 10.4.19.1 22 extendable
ip nat outside source static tcp x.x.x.x 47 10.4.19.1 47 extendable
ip nat outside source static tcp x.x.x.x 143 10.4.19.1 143 extendable
ip nat outside source static tcp x.x.x.x 5901 10.4.19.1 5901 extendable
ip nat outside source static tcp x.x.x.x 5993 10.4.19.1 5993 extendable
07-11-2008 12:41 AM
IMHO this NAT is wrong
if You want access to 10.4.19.1 from Internet i sugest config this:
ip nat inside source static tcp 10.4.19.1 22 x.x.x.x 22 extendable
ip nat inside source static tcp 10.4.19.1 47 x.x.x.x 47 extendable
ip nat inside source static tcp 10.4.19.1 143 x.x.x.x 143 extendable
ip nat inside source static tcp 10.4.19.1 5901 x.x.x.x 5901 extendable
ip nat inside source static tcp 10.4.19.1 5993 x.x.x.x 5993 extendable
and of course
no ip nat outside source static tcp x.x.x.x 22 10.4.19.1 22 extendable
no ip nat outside source static tcp x.x.x.x 47 10.4.19.1 47 extendable
no ip nat outside source static tcp x.x.x.x 143 10.4.19.1 143 extendable
no ip nat outside source static tcp x.x.x.x 5901 10.4.19.1 5901 extendable
no ip nat outside source static tcp x.x.x.x 5993 10.4.19.1 5993 extendable
because wrong direction of NAT generated virtual IP address 10.4.19.1 and conflict
regards
romek
07-11-2008 12:54 AM
Many thanks.
Just so I understand; I did what I did because I thought "source" meant initiator of the connection (i.e. the outside client). Are you saying "source" means provider of the service (i.e. "inside" server) ?
Also, I have designated "VLan1" (the virtual LAN covering the 4 internal LAN ports) as an "inside" interface. Is this right or wrong: i.e. I am assuming "outside" means the internet side.
John
07-11-2008 11:21 AM
John,
That would make too much sense :)
However, the command was structured differently.
Please refer to the following documentation:
http://www.cisco.com/en/US/docs/ios/12_3/ipaddr/command/reference/ip1_i2g.html#wp1079180
and you will find the inside-IP goes before the global-IP.
HTH,
__
Edison.
