07-11-2008 01:26 AM
I am trying to have MP-BGP with my Access Router to Route Reflector first without enabling Acess to core interface as MPLS ( ip mpls)..Do you think that can be issue ?
Chintan
07-11-2008 03:19 AM
HI Chintan, [Pls Rate if HELPS]
First you need to enable the interfaces with below configuration:
mpls label protocol tdp
tag-switching mtu 1546
tag-switching ip
only then the MP-BGP Sessions will be formed successfully.
Hope I am informative.
Pls RATE if HELPS
best Regards,
Guru Prasad R
07-11-2008 03:28 AM
Layer 3 VPNs can be implemented in conjunction with L2TPv3 tunnels. The solution lends itself to implementation where the SP does not implement MPLS transport mechanism in the core to forward packets. Implementation of L2TPv3 tunnels creates a tunnel network as an overlay to the IP backbone, which interconnects the PE routers to transport VPN traffic. The multipoint tunnel uses BGP to distribute VPNv4 information between PE routers. The advertised next hop in BGP VPNv4 triggers tunnel endpoint discovery. Dynamic L3 VPN implementation over multipoint L2TPv3 tunnels provides the ability for multiple service providers to cooperate and offer a joint VPN service with traffic tunneled directly from the ingress PE router at one service provider directly to the egress PE router at a different service provider site.
source is cisco press, MPLS Configuration on Cisco IOS Software, 2005
rate if useful,,,
07-11-2008 03:36 AM
Hi Guru Prasad,
Thanks for you response but I could do some test in my lab and found that MP-BGP can come up even without enabling MPLS on interface.
In live network, I am trying to integrate one of non-MPLS enable in to MPLS and before I enabled interface with MPLS, I want to have MP-BGP with VPNv4 RR but some how it is not comming up. Howerver after doing my test in lab it is clear that MPLS not required to enable to get MP-BGP up.
Chintan
07-11-2008 03:45 AM
I am getting below error message. Can any one let me know what it indicates ?
BGP Notification sent, finite state machine error
Message received that caused BGP to send a Notification:
FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
002B0104 201C005A D44A4575 0E020C02
00800042 00010400 010001
Chintan
07-11-2008 05:32 AM
Chintan,
This message tells you that the notification message has been sent in response to an invalid BGP open message. Here's a decoded version of the dumped message:
FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
00 2B 01 04 20 1C 00 5A D4 4A 45 75 0E 02 0C 02
00 80 00 42 00 01 04 00 01 00 01
BGP Marker: 0xFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
BGP Length: 0x002B - 43 bytes
BGP Type: 0x01 - OPEN message
Parsing OPEN Message
VERSION: 0x04 - 4
AS: 0x201C - 8220
HOLD TIME: 0x005A - 90
ROUTER ID: 0xD44A4575 - 212.74.69.117
OPTIONAL PARAMETERS LENGTH: 0x0E - 14 bytes
Param Type: 2 - Optional Parameter
Param Length: 12
Cap Type: 0x02 - 2
Route Refresh Capability (new)
Cap Length: 0x00 - 0 bytes
Cap Type: 0x80 - 128
Route Refresh Capability (old)
Cap Type: 0x42 - 66
Unknown Capability
Cap Value: 0x - 0
Cap Type: 0x01 - 1
Multi Protocol Capability
Cap Length: 0x04 - 4 bytes
AFI: 0x0001 - 1
Reserved Bits: 0x00 - 0
SAFI: 0x01 - 1
Are the two peers Cisco devices?
07-13-2008 06:43 PM
No.These two peers are not cisco devices.
One is Juniper and other is Cisco.
Could you let me know where could be issue ?
Chintan
07-14-2008 07:19 AM
Chintan,
According to the error message, the BGP open message sent by the Juniper peer is corrupted.
07-11-2008 03:51 AM
so that agree with what i have said earlier mate
it dose not need mpls
mpls for faster forwarding and to decrease the cpu load on the P routers
rate if useful
and about the error sorry i ahve no idea
good luck
07-22-2008 11:12 PM
i would like to share here that my issue is resolved.Unfortuanly, Juniper doesn't work like cisco and we need to enable MPLS globally to negotiate VPNV4 capability with MP BGP peer. It means MPLS is required in Juniper but not in Cisco.
Thanks everyone.
Chintan.
07-11-2008 03:23 AM
you can use map-bgp without mpls enables.
MPLS a way of label switching. as long as you have your VRFs and its RDs and RTs enables and configured properly you can use mp-bgp without mpls
there is a way that ISP and cisco support it for ISP network that dose not have MPLS enabled in its network which it l2tpv3 tunnels
maybe you can use it aswel
search for it there is many documentations on cisco.com about lstpv3 tunnels
good luck
rate if helpful
