mark policy w/ trust dscp
I have a 7604 as a WAN router. I need to use a service policy to mark dscp based on a subnet address using an ACL. In addition to this service policy, I also need to honor dscp markings from things like IP Phones. It appears that its improper to use a service policy input on an interface to set dscp while also using the mls qos trust dscp command on the same interface.
Is there a workaround for something like this, on the same router?
Rupesh Kashyap Fri, 07/11/2008 - 04:46
The logic is same like-
1. Create ACL for the source and destinatiion
2. Create Class Map and match the ACL
3. Create Policy Map and add Class-map in that. Set Voice as DSCP EF or AF41.
4. Bind the Policy Map with interface.
