Migration from NAT+Loopback to "NAT+ip flow ingress/egress"
Jul 11th, 2008
I have NAT users with traffic collection for them.I using mechanism with Route map+loopback. I want migrate to "ip flow ingress/egress"
Here my config:
ip cef
interface Loopback1
description Netflow
ip address 172.19.3.1 255.255.255.0
ip route-cache flow
interface FastEthernet0/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache policy
ip route-cache flow
duplex auto
speed auto
no cdp enable
interface FastEthernet0/0.217
description TO ISP 1
encapsulation dot1Q 217
ip address 217.xxx.xxx.xxx 255.255.255.248
ip access-group 111 in
ip access-group 107 out
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip policy route-map MAP
ip virtual-reassembly max-reassemblies 64
no cdp enable
interface FastEthernet0/0.299
description TO ISP 2
encapsulation dot1Q 299
ip address 195.xxx.xxx.xxx 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
no cdp enable
interface FastEthernet0/0.1143
description TO CATALYST 1
encapsulation dot1Q 1143
ip address 10.3.0.1 255.255.255.0
ip access-group 105 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
no cdp enable
interface FastEthernet0/1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
no cdp enable
interface FastEthernet0/1.1144
description TO CATALYST 2
encapsulation dot1Q 1144
ip address 10.2.0.2 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
no cdp enable
ip nat pool global 82.xxx.xxx.xxx 82.xxx.xxx.xxx netmask 255.255.255.252
ip nat inside source list 100 pool global overload
access-list 101 permit ip any 192.168.0.0 0.0.255.255
access-list 101 permit ip any 172.20.0.0 0.0.255.255
route-map MAP permit 10
match ip address 101
set interface Loopback1
Here config that,how I think must be look like.
ip cef
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
duplex auto
speed auto
no cdp enable
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
no cdp enable
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
no cdp enable
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip nat inside
no cdp enable
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
duplex auto
speed auto
no cdp enable
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip nat inside
no cdp enable
If its wrong can somebody help with config correction.
a.alekseev Fri, 07/11/2008 - 05:01
  • Gold, 750 points or more
You will have twice as much statistic for traffic between interfaces FastEthernet0/1.1144 and FastEthernet0/0.1143.
If you doesn't care about it then you config is correct.
[Pls RATE if HELPS]
seducer666 Sun, 07/13/2008 - 02:59
What you mean "twice as much statistic for traffic" ?
Users connect between each other by local link,the question is only for Internet traffic (users<->NAT<->Internet)
Here my scheme:
ISP1 ISP2
----------7204-G2---------
F0/0.1143 F0/1.1144
Catalyst1---Local---Catalyst2
(nat users) (nat users)
Thanks for help
a.alekseev Sun, 07/13/2008 - 09:22
I just want to say that you will have double statictic for traffic between F0/0.1143 F0/1.1144.
All other statistic (for internet traffic) will be correct.
