MARS Upgrades
Jul 11th, 2008
We had a mars appliance installed by a contractor last year. I am only now starting to look at it after spending most of the time between then and now with CSA and NAC. The version number is 4.2.3. i have noticed that one or two patches have been released from when this box was configured. Do i need to install every patch one by one? Also, am i ok to put 4.3.x as this is still version 4.
Thanks for your help.
Simon
mhellman Fri, 07/11/2008 - 07:12
  • Blue, 1500 points or more
Yes, you do. 4.2.3??? Did the contractor not apply the latest patches? You will need to install the following --have fun! ;-)
4.2.4
4.2.5
4.2.6
4.2.7
4.2.8
4.3.1
4.3.2
4.3.3
4.3.4
4.3.5
Farrukh Haroon Sun, 07/13/2008 - 01:25
  • Red, 2250 points or more
If the data/configs on your MARS box are not important to you, you can re-image the box to the latest version (directly). This is usually not the case. Unless you have to install each minor upgrade separately.
Farrukh
c01642643287 Mon, 07/14/2008 - 01:40
Thanks for the answer.
The contractor was not very good actually. I ended up teaching him how to install CSA after reading lots of books and manuals and his NAC implementation wasnt designed properly. More fun for me though!
Simon
