Telnetting to 2511 constantly requiring (clear line XX)
Jul 11th, 2008
Hello All,
I'm appealing for any help to eliminate the constant frustration of having to type (clear line xx)whenever i am slipping from a router to the access sever to another router.
Please, i urgently seek this help because it's now almost requesting at every moment of changing.
Thanking you in advance
newnetman Sat, 07/12/2008 - 21:27
I'm most grateful for your prompt response and my apologies for replying so late. Anyway, i just want you to know that your reply does not resolve my issue.
Any further assistance shall be greatly appreciated.
newnetman Sun, 07/13/2008 - 13:05
Here is the configuration from the Access server.
Trying R5 (, 2005)...
% Connection refused by remote host
The problem is that whenever i have slip to and from the Access server, i have to issue clear line XX, and this is becoming to frustrating.
Hope i can still be helped further?.
a.alekseev Sun, 07/13/2008 - 13:11
Could you show the output "sh run | b line" on the Access-Server# ?
newnetman Sun, 07/13/2008 - 14:27
Firstly, let me thank you for the willingness to help to me out.
Unfortunately the command you asked me to issue reported an error as follows;
Access-Server#sh run | b line
^% Invalid input detected at '^' marker.
Moreso, may i ask you what the "b" after the modifier stand for?
Secondly, am i correct by saying the RAM and FLASH mem on the router is 2MB each?, according to the underlisted output of the sh ver.
Why i'm saying this is to know maybe insufficient MEM is also contributing to unpredictable behavior of the router?.
cisco 2511 (68030) processor (revision L) with 2048K/2048K bytes of memory.
Processor board ID 06168381, with hardware revision 00000000
Bridging software.
X.25 software, Version 2.0, NET2, BFE and GOSIP compliant.
1 Ethernet/IEEE 802.3 interface.
2 Serial network interfaces.
16 terminal lines.
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read ONLY)
And lastly, sometimes in the middle of implementations upon issuing the "control+shift+6 then X" the router doesn't take me back to the Access server in order to jump to another system. How can this also be resolve?.
My apologies in advance if im becoming a pain in any way. To make answering my concerns easy for you i have labelled the questions as first, second and lastly respectively, please respond in like manner.
avillalva Sun, 07/13/2008 - 16:23
control+shift+6 then X is a bit of an art form. The order is as such -
1. Hold down "control+shift"
2. while holding "control+shift" press 6 once.
3. release all buttons
4. press x
In order to toggle between sessions on the access server type
"show sessions"
in order to access an existing session type the connection number beside the desired host as seen on the show session output.
i.e. 1
newnetman Sun, 07/13/2008 - 16:57
Thanks for the reply. Maybe my massage was not well conveyed concerning the "cntrl+shift+6 then x" command but i meant exactly the as what you messaged.
Any further help to the rest queries?.
newnetman Mon, 07/14/2008 - 02:44
Thanks once again for the willingness to help. In addition to the "Sh run" i'm submitting here could you please help with the associated message in the threads that was listed as first, second and third respectively?.
interface Loopback0
ip address
interface Ethernet0
no ip address
no ip mroute-cache
no ip route-cache
interface Serial0
no ip address
no ip mroute-cache
no ip route-cache
interface Serial1
no ip address
no ip mroute-cache
no ip route-cache
ip host R1 2001
ip host R2 2002
ip host R3 2003
ip host R4 2004
ip host R5 2005
ip host R6 2006
ip host R7 2007
ip host R8 2008
ip host R9 2009
ip host R10 2010
ip host R11 2011
ip host R12 2012
ip host R13 2013
ip host R14 2014
ip host R15 2015
ip host R16 2016
no ip classless
alias exec ct conf t
alias exec sv sh ver
alias exec sr sh run
line con 0
exec-timeout 0 0
line 1 16
session-timeout 30
exec-timeout 0 0
transport input telnet
line aux 0
line vty 0 4
no exec
password password
Edison Ortiz Sun, 07/13/2008 - 21:21
If the connection is used by your current session, you can go back to this session by typing the session number.
Please type show session from the access-server and you will see the number the matches R5.
Type that number in the CLI prompt and it will take you back to R5.
If R5 is not listed in sessions, then this connection was created in previous occasion and you need to clear the line as you are currently doing.
Here is an example how I navigate in my Access-Server:
User Access Verification
Translating "ir1"
Trying iR1 (, 2033)... Open
Translating "ir2"
Trying iR2 (, 2034)... Open
[Resuming connection 1 to ir1 ... ]
[Resuming connection 2 to ir2 ... ]
Please note, to go back to the Access-Server, you need the CTRL+SHIFT+6 (together) then X combination.
