07-11-2008 06:46 AM - edited 03-15-2019 11:54 AM
Hi.
I have a solution with CCM cluster(2) and same SRST in same sites.
When the customer press new call and not dial any digits, after the timeouts, the ip phone autodial to unknown number and after the call change to DN in local site!
Why?
07-11-2008 07:09 AM
This is really interesting!!!! Never seen or heard that before!!!
What version of CCM are you using? I hope its not CCM 5.1.3
07-11-2008 08:40 AM
System version: 5.1.3.2000-3
07-11-2008 08:41 AM
Well, Lots of bugs have been reported on this ccm version..
May be its a bug!
07-11-2008 08:44 AM
do you have a blank translation pattern in there???
javalenc
if this helps, please rate
07-11-2008 08:47 AM
I have 2 translation-pattern
11.! in PT_JRBTB_Local
11.! in PT_ADumas_Local
07-11-2008 08:50 AM
ok, so it might not be a translation pattern. not sure of your version but have you tried deleting all the unassigned DNs??
if you run a route plan report do you see anything blank??
javalenc
07-11-2008 09:04 AM
07-11-2008 09:06 AM
07-11-2008 09:08 AM
you would need to enable a CUCM detailed trace to look into this
javalenc
07-11-2008 09:44 AM
When I delete the dn or change his partition, all fine ok!
The problem is in DN 9587!
07-11-2008 01:28 PM
weird, only a trace would tell what happens. maybe something in cache memory, have you tried a cluster reboot??
javalenc
