Setting a Subsriber on a schedule
Answered Question
Jul 11th, 2008
Hi All,
we have a department with shared voicemail and wish to close that departments voicemail down at 4pm as no-one will be able to return the calls until next morning, therefore I have created a closed message, created a new schedule with the ammended times and saved the particular subscriber to the newly created schedule. However when making a call to the subscriber it plays the open message.
Any ideas?
Darren.
Correct Answer by ranpierce about 8 years 7 months ago
yes you need to make sure that the alternate greeting is not enabled, if it is it overrides the standard and closed.
Hope this helps.
Randy
Overall Rating: 5 (1 ratings)
5c5administrator Fri, 07/11/2008 - 12:32
thanks for your speedy reply, yes I did enable the closed greeting, is there no other other settings?
Darren.
5c5administrator Fri, 07/11/2008 - 12:33
Darren.
Correct Answer
ranpierce Fri, 07/11/2008 - 13:26
Hope this helps.
Randy
5c5administrator Sat, 07/12/2008 - 10:33
thanks for that, the alternate message was enabled and once disabled the closed message was activated.
Darren.
ranpierce Tue, 07/15/2008 - 07:12
Hey I have not been on for a few days but no problem and glad to help.
Thanks too.
Randy
