Ayodeji Okanlawon Fri, 07/11/2008 - 07:36
  • Cisco Designated VIP,
    2017 IP Telephony
if you are using h.323 gateway, the command is..
csim start X.X.X.X where x.x.x.x =DN you want to call
NB: this is used from the privilege mode
You cant use this with MGCP..
peternnaji Fri, 07/11/2008 - 08:08
Hi thatnks for your response. I use a 1760 h.323 gateway. In the priveledge mode, the command "csim start" is not there and when I do a question mark at the priviledge mode, I dont see the option "csim start".
Ayodeji Okanlawon Fri, 07/11/2008 - 08:14
    2017 IP Telephony
Peter,
its a hidden command.
just type in csim start < directory number u want to call> and hit enter, then see what happens
peternnaji Fri, 07/11/2008 - 08:21
I tried it but got the output below:
Router#csim start 1003
csim: called number = 1003, loop count = 1 ping count = 0
csim err:csim_do_test Error peer not found
Router#
Ayodeji Okanlawon Fri, 07/11/2008 - 08:29
    2017 IP Telephony
what that means is that you do not have a voip dial-peer that is responsible for routing the called number..
you need to have a voip dial-peer that will route the call...
Rob Huffman Fri, 07/11/2008 - 07:37
  • Hall of Fame,
    Founding Member
    2017 IP Telephony, Unified Communications
Hi Peter,
Hope all is well :)It must be entered this way;
csim start
Hope this helps!
Rob
Chad Stachowicz Fri, 07/11/2008 - 08:22
  • Silver, 250 points or more
I want to add that this should NOT be used in any sort of formal testing. csim start does not make a proper RTP stream and therefore negotiations of certain protocols will throw errors that aren't real, seeming like links and connections aren't working, when they actually are! (i.e. try csim start over a QSIG T1 and watch it fails with random error's! )
Cheers,
Chad
