IVR - Supervised Transfer to and External number.
Chad Stachowicz Fri, 07/11/2008 - 08:27
Unfortunatly this is not possible unless I have missed something, happy to be corrected..
Sorry, HTH
Jonathan Schulenberg Fri, 07/11/2008 - 18:21
Chad is correct. Supervised transfer exists only in the traditional sense with busy or ring no answer failure options.
There are two options that I am aware of:
1) In the Successful branch you can add a Get Digit String step or an Explicit Confirmation to get the remote destination to confirm they wish to take the call.
2) Look at a third-party outbound dialer such as Radianta's. This is more for a campaign though so it may not work for what you need.
