vpn issues
Answered Question
Jul 11th, 2008
I've bought an ASA5505 and I'm setting it up as a firewall and vpn server.
After many tries my vpn client connected to the server, but now i can't access to my 'inside' network either to the internet...
What's wrong with my config?
My router (192.168.1.254) is linked to eth0 and my vpn client (192.168.1.10 - assigned by dhcp) is connected to eth7...
Ps: if you have any suggestion to improve my network security feel free to suggest ^_^
(Sorry but this is the first time that I set-up a vpn, so I'm deeply ignorant about this)
Correct Answer by a.alekseev about 8 years 7 months ago
access-list NO-NAT permit ip any 192.168.10.0 255.255.255.0
nat (inside) 0 access-list NO-NAT
access-list SPLIT-T standard permit 192.168.0.0 255.255.255.0
group-policy Tailoradio attributes
split-tunnel-policy tunnelspecified
split-tunnel-network-list value SPLIT-T
no crypto dynamic-map outside_dyn_map 20 set nat-t-disable
no crypto map inside_map interface inside
no crypto isakmp enable inside
crypto isakmp nat-traversal
Overall Rating: 5 (2 ratings)
Correct Answer
a.alekseev Fri, 07/11/2008 - 08:10
carlo-tail Fri, 07/11/2008 - 08:53
Perfect, now it's working! ^_^
Is there any way to propagate local lan hostnames to the vpn client?
a.alekseev Fri, 07/11/2008 - 09:04
Nice to hear
You can propagate WINS, and DNS servers for the client.
[Pls RATE if HELPS]
