CME - CFA to VM showing "forwarded to 6000" rather than to "VoiceMail"
ccpagel
I have a customer who says that when they used to press the CFA softkey and then the messages button the phone would display "forwarded to voicemail". However following some recent reconfiguration the phone displays "forwarded to 6000".
Does anyone know what configuration change would result in changing the display to read "voicemail" rather than "6000".
Chris
Ayodeji Okanlawon
Make sure that under
telephony-service
you have voicemail <6000>
so you should have
telephony-service
voicemail 6000
if this is there...
use the command
create-cnf file
and try again
Please rate all useful posts
Yes it is. I thought that's all would need but it seams it doesn't work.
Chris
