spanning-tree vlan commands
Answered Question
Jul 11th, 2008
hi every body !
I am preparing for ccnp(bcmsn) exam. I am using cisco press book by David Hucaby. In the book i find the command:
spanning-tree vlan vlan-id root{primary}\{secondry}
In the same book i find same command but this time with vlan-list option
spanning-tree vlan vlan-list root {primary} {secondry}
which one is correct?
I mean after vlan, It should be vlan-id or vlan-list?
Does hello timer for bpdu have any bearing on forward delay and max-age timer?
thanks a lot and have a nice day !
Correct Answer by lee.reade about 8 years 6 months ago
They are both correct!
You can change the value for a single vlan, or you can change it for a range of vlans,
spanning-tree vlan 20,25,30 root primary
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_44_se/command/reference/cli3.html#wp1947142
LR
Overall Rating: 5 (2 ratings)
sarahr202 Fri, 07/11/2008 - 12:31
thanks for your reply . could you please tell me if hello timer has any bearing on forward time and max-age timer.
thanks a lot!
