many ATM cells and IP packets input, 0 OAM Cells input
Jul 11th, 2008
I'm seeing a pvc which is showing ATM cells and IP packets in, but 0 OAM and 0 cells/packets output. Note that there are 2 other pvcs on the BVI and both of them seem to be working fine. This is PA-A3-T3 on 7206 VXR. My understanding is that if no OAM cells are received, then the pvc is down and shouldn't see any packets inbound. What would cause such an issue?
ATM3/0.5181 is down, line protocol is down
MTU 4470 bytes, BW 40704 Kbit, DLY 190 usec,
reliability 255/255, txload 61/255, rxload 15/255
Encapsulation ATM
32792 packets input, 2320868 bytes
0 packets output, 0 bytes
65584 cells input, 0 cells output
0 OAM cells input, 2946 OAM cells output
AAL5 CRC errors : 0
AAL5 SAR Timeouts : 0
AAL5 Oversized SDUs : 0
Last clearing of "show interface" counters 08:08:43
interface ATM3/0.5181 point-to-point
bridge-group 44
pvc 5/181
ubr 1536
oam-pvc manage
encapsulation aal5snap
Paolo Bevilacqua Sat, 07/12/2008 - 00:44
The interface itself it's down.
As you mentioned, once it's up, the PVC should remain down due to no response to OAM.
