WLAN Assignment Over Multiple Floors
Jul 11th, 2008
Greetings, i have a client who has a number of laptops that will be used across several floors in the same building. The client laptops will physically move location each time they are used but dont need to roam between floors.
Im having to use WPA2 PSk's for authentication and encryption as radius/certificates arnt an option at present.
Would you say it be better to just configure a single WLAN for all floors with a global PSK or separate WLAN's for each floor along with separate PSK's? Which would in turn be configured on the client machines manually?
This is more of a design question really, but any advice would be appreciated.
Scott Fella Fri, 07/11/2008 - 14:20
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Are the ap's autonomous or lwapp?
exonetinf1nity Fri, 07/11/2008 - 14:22
Apologies they will be lightweight distributed across two controllers.
Scott Fella Fri, 07/11/2008 - 14:28
  • Hall of Fame,
    2017 Wireless
You can always use ap groups. This way you can have one ssid tied to multiple subnets (one subnet per floor). Depending on how many devices, you can always go with one ssid all in one subnet. Keep the ssid and encryption the same just in case. How much does the signal bleed through the floors?
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008073c723.shtml
exonetinf1nity Fri, 07/11/2008 - 14:31
Cheers for the information, i haven't been able to undertake a wireless survey unfortunately but the floor and ceiling is approx 3 feet of solid concrete so i dont imagine there be any crossover between the floors.
Scott Fella Fri, 07/11/2008 - 15:21
  • Hall of Fame,
    2017 Wireless
It deends on number of users. I don't like to have a subnet larger than a class C, in some cases I have had subnets deployed that are a /23. So this is where you need to assume how many devices per floor on a given subnet. If you have around 200 devices that will use psk, then one ssid and on subnet.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
