PRI Tie Line
Jul 11th, 2008
I need to configure a PRI circuit that will be used for a "tie line" between two sites. The gateway will be h.323 and I have configured regular pri's before, just not for tie line.
Is their any special commands I will need to add for the tie line portion?
Paolo Bevilacqua Sat, 07/12/2008 - 00:40
Are ou connecting two PBXs using two GWs ?
If so, yest the commands are the same as for a regular PRI.
Please rate post if it helps!
