PCR/SCR values in 3640
Answered Question
Jul 12th, 2008
Hello Networkers !!
Need a clarification on an ATM configuration ,
Today we have installed a new ATM circuit , where i have been asked to set a PCR / SCR value of 4096/3072 .. And I own a 3640 Router with a loaded IOS version of c3640-is-mz.122-12a.bin and I have the IMA 4 port E1 Port adapter, 4 ports installed.
But I was not able to set the PCR value to 4096 as it allows only a max value of 3840 , Is this limitation due to Hardware / Software.
And im able to get this value in 2800 Intergerated routers ??
Any clue !!!! Thanks in advance !!
Correct Answer by Paolo Bevilacqua about 8 years 8 months ago
Hi, the router is correct.
Your E1 circuits are using 30 timeslots of 64 kbps each, so they are 1920 Kbps. times 2, = 3840.
To run a PCR of 4096, you SP should give you unframed E1 circuits that are the only ones running at true 2048 Kbps.
Hope this helps, please rate post if it helps!
Overall Rating: 5 (1 ratings)
Correct Answer
Paolo Bevilacqua Sat, 07/12/2008 - 09:06
  • Hall of Fame,
    Founding Member
Paolo Bevilacqua Mon, 07/14/2008 - 11:16
  • Hall of Fame,
    Founding Member
Sometime SPs are unable to provision unframed E1 due the equipment they're using, or other issue.
A small improvement would be using using 31 timeslots instead of 30. Currently you are not using TS 16.
In any case, it's impossible by definition to configure a PCR larger than access speed.
Thanks for the appreciation and good luck!
