interface error
Jul 12th, 2008
Dears,
I have two E1 connections connected to 3745 router ,the ouput of show interface command for one of these interfaces gives a high counters value for input errors and CRC and the counters keep increasing ,also the relaibility of this interface has a value of 228/255??!!
what this indicates .????
paolo bevilacqua Sat, 07/12/2008 - 09:01
  • Hall of Fame,
    Founding Member
Most likely your circuit is errored, check "show controllers E1".
guruprasadr Sat, 07/12/2008 - 11:08
  • Gold, 750 points or more
HI, [Pls Rate all Informative POST]
Request your ISP to check / test the circuit. There are some reliability Issue reported.
Guru Prasad R
csco10716389 Sat, 07/12/2008 - 12:07
PLease contact your service provider and discuss about the reliabiliity of your E1 link.The reliability should be 255/255.Your current reliabilty shows that there should be some problem with the media.
sdoremus33 Sat, 07/12/2008 - 14:36
  • Bronze, 100 points or more
Either
A. Circuit framing timing check the interface
sh controllers E0/E1
B.Layer 1 physical issue check with your ISP
