ASA Nat or ACL
Answered Question
Jul 12th, 2008
Which is the better to deny certain ip addresses on the inside interface access to the internet:
1. Do not setup the specific ip adresses with NAT rules.
2. Create an ACL to deny access for the specific network addresses.
Correct Answer by JORGE RODRIGUEZ about 8 years 7 months ago
I would have a different approach.
You could create a network object group called internet access, add hosts to that group that will be permited internet, you would just need to add a host in the ubject group or remove the host for no internet. I think it is much easier this way than have many access lists per host Ip, or many nat statements.
example
object-group network Subnet_20.20.20.0
description: Outbound_Internet
network-object 20.20.20.20 255.255.255.255
network-object 20.20.20.21 255.255.255.255
and so on ..
create a single access list allowing outbound internet access
access-list inside_access_in permit ip object-group Subnet_20.20.20.0 any
access-group inside_access_in in interface inside
or you could revert the above to block internet access with a negate access-list, add hosts to the group for no internet.
Jorge
Overall Rating: 5 (1 ratings)
ray_stone Sat, 07/12/2008 - 16:32
Hi, here i would suggest you to create an access-list or you can go by making AAA Server.
Correct Answer
JORGE RODRIGUEZ Sat, 07/12/2008 - 16:35
example
and so on ..
Jorge
sjones1966 Sat, 07/12/2008 - 18:19
Thanks Jorge - I had been using Nat statements to permit/deny ip access but while at first these were quite simple as requirements have changed over time the list has grown and looks messy. To keep the NAT statement simple I had even considered changing ip addresses of devices but unfortunately this isnt feasible.
I like your solution as it will provide a single location to maintain all internet access from.
I guess it will also alert me to any denied devices that may be trying to access the internet.
While not a problem for me is there any potential impact on performance using acls over omitting addresses from NAT statements?
