Can't PPTP out of network with ISA and ASA
Jul 12th, 2008
I have a network configuration with two firewalls. ASA5510 is the first level of security and then Microsoft ISA is the next level of security before traffic enters the LAN. The problem I am faced with is that PPTP works inbound to the LAN but would not work on the outbound. I tried turning off the inspection but this doesn't help. I temporary replaced the ASA5510 with a 2821 router configured as a firewall and this works perfectly. Can anyone tell me why the ASA5510 would not allow the outbound PPTP connection. It works ok if the ASA5510 is standalone.
a.alekseev Sun, 07/13/2008 - 09:58
  • Gold, 750 points or more
show the configuration...
a.alekseev Mon, 07/14/2008 - 13:56
you have two static
static (inside,outside) tcp interface pptp 172.16.0.2 pptp netmask 255.255.255.255
static (inside,outside) tcp 64.180.2.2 pptp 172.16.0.3 pptp netmask 255.255.255.255
which is not working?
wdbrewster Mon, 07/14/2008 - 15:15
These are inbound to the network, these are working fine. The problem is that I am unable to pptp from inside the network to any host outside.
