Telnet Issue
Answered Question
Jul 12th, 2008
If Switches without username and password, we cannot telnet in.
But what if Acess Point without one, are we able to telnet in?
Correct Answer by Scott Fella about 8 years 10 months ago
1) Yes you will
2) You need login local
3) Yes with (bbb)
4) No... you either have a password or use login local.
Here is a link that will help you better understand.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1818/products_configuration_example09186a0080204528.shtml#pw-line
Overall Rating: 5 (1 ratings)
Scott Fella Sun, 07/13/2008 - 08:36
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
For autonomous ap's you need to supply a local login or vty password. If you have a WLC and LAP's you can telnet to the WLC if you have that enabled, but you can't telnet to the LAP.
kian_hong2000 Mon, 07/14/2008 - 07:07
I have some other questions.
I notice that the vty are spilt into line vty 0 4 and line vty 5 15.
1) Now i did not put the username and password but instead i put a password in the line vty 0 4, will i still be able to telnet in?
2) I put a username and password (aaa) to the configuration but this time no password inside vty 0 4. Will i be able to telnet in?
3) Now i add in a different password (bbb) into the same configuration line vty 0 4, can i still be able to telnet in?
4) Say line vty 0 4 password is (bbb), line vty 5 15 password is (ccc) and the username 123 password (aaa).
Can i say the fifth telnet to the switch is using either (aaa) or (ccc) password?
Correct Answer
Scott Fella Mon, 07/14/2008 - 17:57
  • Hall of Fame,
    2017 Wireless
1) Yes you will
3) Yes with (bbb)
