Easy VPN: New loopback interface created for every connection
Jul 12th, 2008
Dear friends,
Headend is VPN Concentrator and remote end is IOS router. Mode is network plus.
Everytime, the IOS router re-connects, a new loopback interface is created with a new IP from an address pool. The number of loopback interfaces keep increasing on the IOS router after each connect / re-connect.
Is this a normal behaviour. I would ideally like the old loopback interface to be deleted if a new one is created. Or i would like the old loopback interface be modified with the new available IP from the address pool.
Is there any workaround for this?
Thanks a lot
Gautam
a.alekseev Sun, 07/13/2008 - 12:53
What do you mean? Could you show it?
sh ip route conn
sh ip int brief
