FWSM auto reboot problem !!!
Jul 12th, 2008
Dear all !
I have a problem with FWSM. I've used ver: FWSM Firewall Version 3.2(3). and configured Failover in two chassis 6509. The firewall system have worked for 8 months but this is the second times the FWSM auto reboot. The first time has happended a month ago.
the system has log like this :
-C6KPWR-SP-4-DISABLED power to module in slot 1 set off (Reset)
-DIAG-SP-6-RUN_MINIMUM Module 1: Running Minimal Diagnostics...
-DIAG-SP-6-DIAG_OK Module 1: Passed Online Diagnostics
- OIR-SP-6-INSCARD Card inserted in slot 1, interfaces are now online
there is no log before this event !
Please give me some advises !
Thanks so much !
I had one do something similar but I could never work out what the problem was so I had to send it away to be repaired. I did try a few things beforehand though so maybe they'll help you.
1. Try running the diagnostics on the blade. There is a memory check amongst other things.
2. Try looking for dump files that might be created when it crashes. You may have to put the blade into maintenance mode for that but try just looking in flash first.
3. You could try changing the physical memory if you have some spare.
Does it happen under specific conditions - heavy load etc?
Good luck!
pocketldq Thu, 07/17/2008 - 19:08
hi Anthony !
I've tried but I could't find any thing about that, There's no log, except module reset logs.
the FWSM don't work in hard load condition. about 600Mbps in/out and 15% connection capacity.
I thinks i have to send it back to warrant.
WEERAKOO69BA Sat, 01/22/2011 - 23:17
Dear pocketldq
Can u tell me how did you solve this issue??Did u replace the card??I have the same problem in one of my customers.
Kureli Sankar Sun, 01/23/2011 - 06:18
Pls. open a case with TAC.  Issue "sh crash" and if there is a crash file saved, attach that to the TAC case.
TAC will decode the crash and suggest and upgrade if needed.
