CM Incremental Upgrade :- apply to Active or Inactive partition ??
Answered Question
Jul 13th, 2008
I have a CM system with 5.0 (inactive) and 5.0(4) (active).
TAC suggested that I upgrade from 5.0 --> 5.0(5) ---> 5.1(3)
Now, to upgrade from 5.0(4) --> 5.1(3) do I need to first change my
Active Partition back to 5.0, and then upgrade the inactive partition ?
Or do I stay in my active patition (most current) and start the upgrade process ?
Correct Answer by Ayodeji Okanlawon about 8 years 9 months ago
I will follow thet docs. That for me is reliable.
Please rate useful posts...
Overall Rating: 5 (1 ratings)
Ayodeji Okanlawon Sun, 07/13/2008 - 06:27
  • Cisco Designated VIP,
    2017 IP Telephony
You can upgrade directly from 5.0(4) to 5.1.1 and then to 5.1.(3).
So you should start from 5.0(4) which is your active partition and upgrade to 5.1.1 and then to 5.1.3.
The document below shows the upgrade paths available for ccm
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008086cc7c.shtml
shahedvoicerite Sun, 07/13/2008 - 07:30
Thanks!
TAC seemd to suggest that an upgrade from 5.0(4c) to 5.1(3?) was possible, although the docs disagree.
To be cautious, I will try upgrading to 5.1(1c), and then to 5.1(3c)
Thanks.
Correct Answer
Ayodeji Okanlawon Sun, 07/13/2008 - 07:47
    2017 IP Telephony
