expanding dn's in callmanager
Jul 13th, 2008
Hi:
customer has a 6.1 callmanager and wants to change all 4-digit extensions to 7-digit.
Is there an easier way to do it besides manual?
Example would be to take all ext's 5XXX and change them to 1235XXX.
the phones were migrated from a 4.1 callmanager so there are no BAT files.
thanks
Rob
Chris Deren Sun, 07/13/2008 - 07:00
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Without custom tool development your best option would be to export all phones and reimport them with the new DNs. Sorry, no native way in CM to accomplish this easy.
Chris
rvincent Sun, 07/13/2008 - 13:35
Chris:
If you export phones, change dn's and re-import them - do they overwrite what's there or do you need to delete them in ccm before importing?
Rob
Jaime Valencia Sun, 07/13/2008 - 17:41
  • Cisco Employee,
  • Hall of Fame,
    2011
you need to delete before reimport, otherwise CUCM will tell you the MAC address is already in the system
javalenc
if this helps, please rate
rvincent Mon, 07/14/2008 - 03:48
Guys:
using bat admin>export phones, gives a txt file. Do you modify that and upload it into ccm or do you take the data and put it into a bat macro spreadsheet to create a xls file for import, like you do with new ?
Deleting phones would also cause the user device associations to be lost - yes?
Rob
Jaime Valencia Mon, 07/14/2008 - 03:56
  • Cisco Employee,
  • Hall of Fame,
    2011
you modify directly the TXT as you will use the import all options and not a template, device association should be on the file so it will be kept
javalenc
rvincent Mon, 07/14/2008 - 05:47
okay, thanks.
what i found was that you can upload the modified text file and when you use that file to "insert phones", checking the "override existing configuration" box will modify the phone fields and you do not need to delete any phones.
Also, as you said, the user device association remains.
thanks again
Rob
