ASA 5520 remote vpn disconnection prb.
Jul 13th, 2008
Dear all,
I have an ASA 5520 and configured remote vpns. when i connect 3 remote vpn's it is working perfectly when i try to connect 4th remote connection it is disconnecting one connection from the 3 active connections.not able figure out whats wrong.please help.
im attaching the configuration.
Marwan ALshawi Sat, 07/19/2008 - 01:42
under ur group-policy config attributes
use the following command
and specify the number with that comman
which let u Specify the maximum number of simultaneous logins
good luck
Rate if helps
