Remote access to Home Lab
Jul 13th, 2008
I have several Cisco routers and switches used as my home lab that I would like to access remotely while at work or on the road. I have broadband modem with no static IP. I am looking for suggestions on how I can connect to my terminal server at home through my cable modem. Any ideas would be appreciated. Thanks,
paolo bevilacqua Sun, 07/13/2008 - 13:32
  • Hall of Fame,
    Founding Member
configure DDNS on the router, the manual explains how. So you will always know whta's the address it got.
Then you can configure to use the VPN client and this will give you access to all the devices directly.
More simply you can configure static ip nat to telnet to individual devices using different ports.
