Chad Stachowicz Thu, 07/17/2008 - 16:30
  • Silver, 250 points or more
As far as I know enterprise data in CAD is per agent, said and done. I don't think you can get as granular as per state. Enterprise data does not work as granuarly as WorkFlow's :)
HTH, please rate useful posts
Chad
c-pinilla Mon, 07/21/2008 - 22:19
Using IPCCX you can configure enterprise data to be modified by agents during calls. After a call enterprise data is showed until a new call rings. We want to modify the enterprise data between calls.
Thanks.
Carlos
