ACS enable secret
Answered Question
Jul 13th, 2008
dear where is the menu is the acs to centralize "enable secret" so in router or switch there is no "enable secret" because it already moved to ACS. Tq anyway
Correct Answer by dhananjoy chowdhury about 9 years 2 weeks ago
Go to Interface Configuration, TACACS+ (Cisco IOS),under the Advanced Configuration Options >> check the option "Advanced TACACS+ Features"
After this you will see the enable password options.
Overall Rating: 4 (1 ratings)
Jagdeep Gambhir Mon, 07/14/2008 - 04:53
  • Red, 2250 points or more
ACS--->User setup----> TACACS+ Enable Option.
Here you can set it of each user
~JG
Do rate helpful posts
Correct Answer
dhananjoy chowdhury Mon, 07/14/2008 - 06:26
  • Silver, 250 points or more
